lavaheadache
I need to know where I can find one of those things. I think it is a power inductor. I don't know what the specifics are regarding it.
Any help would be great.
Before I removed the one that burnt up, having the card plugged in kept the pc from turning on. After removing the charred up component the pc boots and appears to work fine but I ant to replace the component anyway. I'm good with a soldering Iron I just need help with the part.
Thanks
