Need help with " ALL In Wonder'
Rachet
I have had a constant problem with my ATI AIW x800XT since I purchased it a few months ago.
I decided to delete all of the ATI programs and re install all of the software.
I removed all of the software, ran a "driver cleaner" software and installed the latest drivers and MMC programs.
My system still doesn't work correctly, each user on my machine has a problem although it varies slightly by user.
Part of the problem is that I can't seem to delete each users preferences for using the MMC portion of the AIW. Does anyone know where the user preferences are kept and is a simple delete of the file enough to get the program to switch to default settings once I reboot?
My problems are audio based, either echos, audio lag, or no audio at all.
