Need help with access 2003 query
StageLeft
70,150
This is annoying me. I have this query and it's good in SQL:
UPDATE [T 99] SET [Part Number] =
(SELECT x.[new part] FROM xref x
WHERE x.[old part] = [T 99].[Part Number])
As you can see, it updates a field in T 22 based on a cross referenced value in xref table. xref has only "old part" and "new part"
In access, however, I get this error:
"Operation must use an updateable query."
Google is no help. This is a common problem, but no solutions on google fix me. I am an admin on this machine and the database is on my local box. I have tried this:
DLookup("[new part]", "xref", "[old part] = [T 99].[Part Number]")
and when I hit run nothing happens. There is no error, no indication as to how many records to update, nothing at all. It's like Access cannot update an entire table based on matching records in another table. My last resort here is to import the entire thing into SQL, run the proper update query, then export back out to Access, but that is a really silly option.
I am eternally indebted to whomever helps!
KLin
30,952
1,080
UPDATE [T 99] INNER JOIN xref ON [T 99].[Part Number] = xref.[Old Part] SET [T 99].[Part Number] = [xref].[New Part];
StageLeft
70,150
I won't know if it works for a couple hours, but it looks like it probably will. I'm so used to the other way I was doing it that I didn't think of a join :(
Markbnj
Elite Member <br>Moderator Emeritus
Moderator
Sep 16, 2005
15,682
14
www.markbetz.net
As facilitator for this transaction between parties, the Anandtech Moderator for Programming takes $.30 and wishes you all a good day.
Evadman
Administrator Emeritus<br>Elite Member
Feb 18, 2001
30,990
:laugh:
KLin
30,952
1,080
I am foregoing the stated fee, therefore you get...NOTHING. HAH :p
StageLeft
70,150
hehe
Don't worry about it.
Thanks, but seriously it could get you almost half of a coffee from starbucks!!
KLin
30,952
1,080
hehe
Or 3 McDouble's from MickeyD's!!! I may have to rethink your offer.
KLin
30,952
1,080
Access is very fickle when it comes to action queries.
StageLeft
70,150
Yes it sure is!
