The only board installed is the video.
The VIA latest drivers are installed. I have installed the Win98se update for USB.
The first time the USB is installed it will work until the computer is rebooted and will then hangup.
If I remove the USB cable eveything will work as normal until I plug in the USB.
I have tried using a USB scanner and a Smart Media Card Reader. The hangup will happen anytime after the computer is running and the USB pluged in.
I have also tried using only Win98se with no other software or drivers installed. The same hangup occurs.
I have tried both ways of setting USB IRQ in the bios. Enabled and then Disabled.
Thanks for any help you can offer.
