need help with a7v133
meltedmind
13
i have an a7v133, a 1.3Ghz athlon, 256 pc133 ram. the problem is i cant seem to get it to run at 133fsb. it will do 132x10.5 and most multipliers below but the thing will not doe 133x anything. i would like to up the fsb and lower the multiplier. wahts going on and how do i fix it.
Davegod75
5,320
what bios revision do you have on there?
Sounds like something with the PCI divider not clicking in
AquamanA
53
Back off your system timings and see if it will do 133
i.e.
1) Set RAM to 3-3-3
2) Set system performance to normal
Perhaps your ram can't handle 133
3) Up the VIO to 3.45V if you're at 3.3 V now. Might increase high FSB stability
good luck
