I have a desktop and a ibm thinkpad T41 with wifi "b". My network is wep enabled. I initially had a netgear g router. I had no problems on my desktop which was directly connected to the router, but my laptop used to lose connection very often and show more than one internet connection is available, even though my signal would be the strongest and I did delete the other networkd from the connection sequence. ( I live in a townhome-neighbours also have wireless set up)
I was told it could be a router problem and hence switched to a belkin g. The above problem was solved by this switch. Never drops a connection. But a New Problem surfaced.
This problem is on both the desktop and the laptop. After a few minutes of idle time on the desktop or standby on the laptop, there is no connection. I have to restart the computers to get back online. The router does not switch off, but the only way to get back online is to restart the computers.
I use comcast hsi.
I reset the router and tried it and nothing has changed. I'd appreciate if experts here could share their opinions or views. I'm not a tech expert. Did I configure the network wrong?
I have checked belkin.com for firmware ugrades, but did not find any. I spoke to a couple of my friends and no one has ever had this problem.
I use comcast hsi.
