Need help with a virus.
ForumBlue
I got a virus yesturday, that installed a toolbar into IE called "Security Toolbar 7.1" after talking to several people and trying many things I was able to get rid of the toolbar with a program called "UnHackMe". My problem is that that wasn't the only thing wrong. When ever I Google Search something, I get the list of sites but when I click on the link it redirects me to other oddball sites and always seems to end up at a page called "FUNSPLACE" which is just a blank page.
Also since thius all happened I noticed 2 progams in my ADD/Delete Programs list called "Secure Browsing" and "Web Application" If I try to remove these I get a window that says "You should reboot your computer prior to uninstalling this software. Reboot now?"
and the only options are "OK" or "Cancel". If I reboot and try it again it does the same thing.
I was thinking this may be related to my problem as I don't remeber seeing this in the list before., but not sure.
Any help would be appreciated. Keep in mind I am a Computard so the simpler the better.
Thanks.
mechBgon
Oct 31, 1999
30,699
Welcome to the Forums. Could you download HijackThis, run it, and have it scan and generate a log. Then post the output from the log in a reply and you'll get advice on what to have HJT remove.
