Need Help with a VBA issue in Excel
dohara
To start I am a noob. I literally just looked a VBA for the first time yesterday. So I appreciate if you dumb up your replies. lol.
A couple times a week I am given a spread sheet at work. I have to split the zip codes and move them to there perspective Store. There is about 20 zip codes and although I use the sort option, It still takes me awhile. I want to use the marco to pretty much give each zipcode a store.
Here is my issue. I am trying to look at "J1" if the zip code matches one of many I want "Bullhead" to be written in "M1"
I was able to do this, It took me several hours of trial and error to come up with the best result. I tried a lot of different things. (At the very bottom is what I came up with)
Here is the problem. I need to do this all the way down the spread Sheet. ie. if J3 = 86409 M3 = Kingman. If J4 = 86409 M4 = Kingman. So on and so on all the way to J5000,M5000.
Any help would be greatly appreciated. What I want to do is simple but I could not find the answer on my own, or I could not understand it. I assume I will have to start over. And take a different approach. Not sure what though.
Sub MoversBirthdays()
Dim zipcode As Long, Store As String
zipcode = Range("J2").Value
If zipcode = "86426" Or "86427" Or "86429" Or "86430" Or "86435" Or "86436" Or "86437" Or "86438" Or "86439" Or "86440" Or "86442" Or "86446" Or "89028" Or "89029" Or "89046" Or "92304" Or "92332" Or "92363" Then Store = "Bullhead" Else: Store = "Kingman"
If zipcode = "" Then Store = ""
Range("M2").Value = Store
End Sub
If you wish to take the VBA macro approach I would make it a function and put the function in the spreadsheet cell M4 like =MOversBirthdays(J4)
When you drag down the column M4 it will auto increment the value passed in from cell J5 J6 J7.. to the function
Code:
Function MoversBirthdays(zipcode As String)
Dim Store As String
If zipcode = "86426" Or zipcode = "86427" Or zipcode = "86429" Or zipcode = "86430" Or zipcode = "86435" Or zipcode = "86436" Or zipcode = "86437" Or zipcode = "86438" Or zipcode = "86439" Or zipcode = "86440" Or zipcode = "86442" Or zipcode = "86446" Or zipcode = "89028" Or zipcode = "89029" Or zipcode = "89046" Or zipcode = "92304" Or zipcode = "92332" Or zipcode = "92363" Then Store = "Bullhead" Else: Store = "Kingman"
MoversBirthdays = Store
End Function
A better way to do this is with the VLOOKUP function. Maintain a sheet of zipcodes and their corresponding stores. Then use VLOOKUP to bring the name over:
http://www.techonthenet.com/excel/formulas/vlookup.php
Problem Solved
Dim varZip As Variant
Dim arrStore() As String
Dim StoreIndex As Long
With Range("G2", Cells(Rows.Count, "G").End(xlUp))
If .Row < 2 Then Exit Sub 'No data
ReDim arrStore(1 To .Rows.Count)
For Each varZip In .Value
StoreIndex = StoreIndex + 1
Select Case varZip
Case 86426 To 86427, 86429 To 86430, 86435 To 86440, 86442, 86446, 89028 To 89029, 89046, 92304, 92332, 92363
arrStore(StoreIndex) = "Bullhead"
Case ""
arrStore(StoreIndex) = ""
Case Else
arrStore(StoreIndex) = "Kingman"
End Select
Next varZip
End With
If StoreIndex > 0 Then Range("I2").Resize(StoreIndex).Value = Application.Transpose(arrStore)
End Sub
