tangotracker
I've got a SkyHawk SFF machine that I just put together which uses an ACorp 4865GQET motherboard, based on the Intel 865G chipset.
All in all it runs great and in some ways better than expected, but there is an issue that I can't figure out unless it's just a BIOS problem, however neither SkyHawk or ACorp have any technical support to speak of.
Basically if you use the onboard video the in the POST report just prior to boot it will show USB 1.0/1.1 Controllers and the USB 2.0 Controller.
However if you install any AGP video card (I've tried 4 different ones) it will only POST with the USB 1.0/1.1 Controller and without USB 2.0.
Take the AGP card out and it comes back no problem.
I've disabled the serial and parallel ports to save IRQ room and flipped everything I can think of that might have an impact with no results.
Any ideas?
