Need help with a Shell Script
drgnlvrs
47
I have a program that is passing a variable with several names in it: a$ = rich, tom, chuck, pat
I want to replace the commas with an email extension like @yahoo.com
The result should create a variable with the information like this:
Names$ = rich@yahoo.com, tom@yahoo.com, chuck@yahoo.com, pat@yahoo.com
What is the easiest way to do this in a shell script.
Thanks for your help.
Barnaby W. Füi
12,343
That syntax doesn't look like a shell script to me. What kind of shell script, exactly?
And if you only replace commas, the last name won't get an @yahoo.com.
In bourne shell:
a="rich, tom, chuck, pat"
Names=`echo -n $a | sed 's/,/@yahoo.com/'`@yahoo.com
drgnlvrs
47
Originally posted by: BingBongWongFooey
That syntax doesn't look like a shell script to me. What kind of shell script, exactly? And if you only replace commas, the last name won't get an @yahoo.com. In bourne shell: a="rich, tom, chuck, pat" Names=`echo -n $a | sed 's/,/@yahoo.com/'`@yahoo.com
The names are not the Shell Script, they are the data the variable contains that I need. I want to append the rest of the email address to each of them, so need to be able to read them seperately.
Using AWK, I was able to add the email address but am not able to pass the variable with the whole addresses out of the AWK statement.
I am just trying to find the easiest way to do this, so far it seems like I just keep jumping through hoops for something that should be pretty simple.
Thanks.
Barnaby W. Füi
12,343
Well duh. I've never seen the "foo$ = bar" syntax before, it's definietly not bourne shell syntax, and I'm pretty sure csh doesn't look like that.
Thanks.
Hello? I gave you an answer.
drgnlvrs
47
Originally posted by: BingBongWongFooey That syntax doesn't look like a shell script to me. What kind of shell script, exactly? And if you only replace commas, the last name won't get an @yahoo.com. In bourne shell: a="rich, tom, chuck, pat" Names=`echo -n $a | sed 's/,/@yahoo.com/'`@yahoo.com
I want to append the rest of the email address to each of them, so need to be able to read them seperately. Using AWK, I was able to add the email address but am not able to pass the variable with the whole addresses out of the AWK statement. I am just trying to find the easiest way to do this, so far it seems like I just keep jumping through hoops for something that should be pretty simple. Thanks.
Sorry, I missed your comment at the bottom. I will give that a try tommorow. Thanks.
