Hello friends,
As you will make out from the grade of my questions, I am a first timer in building a PC.
I really need your help on a system I am attempting to build. THis is going to be my primary machine + I want to run it as a HTPC with a front projector via DVI/HDMI.
I am not into gaming at all and dont think would do any overclocking.
On the motherboard, I was considering 2 options, either get a nVidia based motherboard (like the GIGABYTE GA-E7AUM-DS2H)
or get a p45 motherboard (GIGABYTE GA-EP45-UD3LR) and add a Graphics card (XFX PVT95GYALG).
Had a tough time deciding between the two.
Let me know what you think.
Other than that, here are the rest of the components I picked out.
Please let me know if they go together well.
Rosewill R218-P-BK Black 0.5mm SECC Steel ATX Mid Tower Computer Case - Retail
Western Digital Caviar Green WD10EADS 1TB SATA 3.0Gb/s Hard Drive - OEM
XFX PVT95GYALG GeForce 9500 GT 512MB 128-bit GDDR2 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card - Retail
APEVIA ATX-CW500WP4 500W ATX Power Supply - Retail
CORSAIR 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model TWIN2X4096-6400C5 - Retail
GIGABYTE GA-EP45-UD3LR LGA 775 Intel P45 ATX Intel Motherboard - Retail
Intel Core 2 Duo E7400 Wolfdale 2.8GHz LGA 775 65W Dual-Core Processor Model BX80571E7400 - Retail
What is the max PSU wattage that I need for this kind of a system?
How many fans?
Also, this set up is really pushing my budget. I started off with <$400 but this ones taking me close to $500.
Any suggestions on getting it down..
Really appreciate your help.
- RP
How many fans?
- RP
