- Feb 16, 2015
- 21
- 0
- 0
http://pcpartpicker.com/p/vXPNZL
This is the build as it stands. Its over-budget by a bit. To answer the helpful questions:
1: I'm attending college online. This requires the use of VMWare. I also game some, primarily Path of Exile and Borderlands 2, although with the new hardware I should be able to play more demanding games
2: I have a $1000, but I need to allocate $200 to a new phone, that leaves me $800 for the computer. This is a firm budget, although I have a few parts already. Promos will help, rebates will not as I want to order everything at once. I'll take rebates if offered, but I need to be at or under $800 before the rebates are counted.
3: I live in Florida, all parts will be bought from the US
4: N/A
5: My brand loyalty is my wallet. I'm under the impression that at my budget that an Intel i5 would be best. I'm certainly open for ideas though.
6: I already have a monitor (hpw2338h) It caps at 1920x1080, and I expect to use it for several more years. I have a 500gb hdd I plan on taking from my current computer to use in the new one. I also have a keyboard. I will be getting my OS from college, so that doesn't have to be counted against the budget. I will need everything else, including a mouse as the one I currently have will be handed to my kids with the rest of the current computer.
7: I don't plan on overclocking as any computer I put together is going to blow this one out of the water. Having said that, my pcpartpicker list does contain an aftermarket cpu cooler as I'm not sure about how good the boxed coolers work.
8: My monitor is 1920x1080
9: I would like to order the parts on Friday 2/20
10: No outside software. I will get the OS on my own, and it doesn't count against the budget.
A few thoughts of my own.
1: My list is kinda sorta built from Tomshardware monthly part lists and partly from the midrange build here. I need to cut about $125 off my list.
2: Simple cuts I can think of on my own are as follows
Hyper 212 Evo
Antec P100 Case
Steel Series Rival Mouse
Less sure of:
Corsair CM 650W
GTX 960
ASRock H97 motherboard
3: I "only" game at 1080p, I'm hoping that means I can go a little less on the video card. Every computer I've built has gotten a newer video card after a couple years, I've never replaced the processor. If the GTX 960 can max most stuff at 1080p, I don't see much reason to go higher that that for now.
4: I honestly have no idea on the motherboard. I know the socket type is compatible, but other than that, I don't know the difference between this motherboard and any other. I have 2 hhds, and will be getting a ssd for this build, will I need extra sata cables if I get this motherboard?
5: With everything else I have, is the PSU more than I'll need? I don't want to skimp and end up short, but I don't want to overdo it either.
6: I could cut some expense on the case. I'm more concerned about function over form. My computer sits under the desk, so I don't need a lot of bells and whistles, I just need something with decent air flow that will fit all the parts.
7: If I can afford it, I would like to get a webcam. Nothing fancy, just something that will allow for video chat via skype.
8: Not hardware related exactly, but how do I go about partitioning the ssd? I generally setup my hdd with a smaller (50gb) partition to hold the OS and minor programs like VLC, and a larger partition to hold all other things. I kinda like that setup, but have never yet used a ssd. Can I partition a ssd the same way I have always done on my hdd?
4: N/A
Hyper 212 Evo
Antec P100 Case
Less sure of:
Corsair CM 650W
GTX 960
