Need Help with a New Build
Oyiwaa
Hello,
Thanks for a very informative forum. I am about to update my 5 year old rig. Haven't build a complete system in years, so this would be fun. I need some advice in putting my components together. Here is what I have / considering:
1. Purpose of computer: Office applications, statistical analysis, audio/video processing and some gaming - WoW, Runescape, Fifa Soccer
2. Budget: $200 - $300 for remaining components
3. List which parts you have and/or which parts you are considering:
a. CPU: AMD Phenom II X4 955 Black Edition Deneb 3.2GHz (http://www.newegg.com/Product/Pro...2GH z%204)
b. Mobo: Considering ASUS M4A87TD/USB3 (http://www.newegg.com/Product/Pro...6813131651)
c. GPU: Considering the XFX HD-577A-ZNFC Radeon HD 5770 (Juniper XT) (http://www.newegg.com/Product/Pro..._-14150447)
d. Hard drive: Will use two old drives - will use existing WDC 640 (SATA) for OS/Applications & WDC WD 80.0 GB (ATA) for data. Considering an SSD drive to run my OS / applications
e. Ram: G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333: (http://www.newegg.com/Product/Pro...6820231426)
f. PSU: XFX P1-650X-CAH9 650W ATX12V v2.2 (http://www.newegg.com/Product/Pro...6817207007)
g. Case: Roomy, good airflow: Considering the Cooler Master Storm Scout SGC-2000-KKN1-GP or the Antec 902
h: Optic (CD/DVD/Blu-ray): Lite-On LH-20A1L (SATA) & TEAC-DVD W58E ATA Device
i. Monitor (size&resolution): Will use existing Dell 1901 FB and Dell 2001FP for dual display. Maximum resolution: 1600 x 1200 (2001FP) and 1280 x 1024 (1901FP). and have analog (D-Sub) and Digital (DVI) inputs. Would upgrade later to an HDMI monitor
4. Overclocking: May not need, but want it as an option.
5. When will you build it: ASAP - when parts are ready.
6. Misc: CPU Cooler -- would be ok, not but urgent, once the case has enough fans
So folks, there you have it. Basically, I have to get a good video card, a case and a motherboard, all for about $300.
I will be running it mainly with win7 Ultimate (possible dual boot with MacOSX, if I can get it working with the AMD processor).
I would appreciate your suggestions.
Thanks again for this informative forum.
rgds, Oyiwaa
I'm confused, which if those components have you already purchased and which have not been purchased? You can probably do a Sandy Bridge build for similar or slightly more than the Phenom II. Sandy Bridge will be much faster and have better Hackintosh potential.
Mfenn,
Thanks very much. I have everything except the Case, Motherboard and Video card. I have about $300 to spend on these.
Since I've bought the CPU (AMD) already, Sandy Bridge is probably out of the question, unless I can sell it.
Thanks .. Oyiwaa
Mfenn,
Thanks .. Oyiwaa
In that case, go with what Mnewsham suggested.
Thanks Mfenn and Mnewsham,
I really like the GTX 460 1gb, and would get it for my build. If I need to increase my price point for the motherboard a bit, what would you suggest ? Should I still go for the ASUS M4A87TD/USB3?
thanks - Oyiwaa
thanks - Oyiwaa
If you were to increase your overall budget by $40 (do not think in terms of budgets for individual components), you should keep the same motherboard but get a GTX 560 Ti instead.
