Setting up a machine from used parts...I have a 60 gig WD that has one NTFS partition. What I want is two
partitions but fdisk isn't erasing the NTFS partition...someone told me there is a low level format utility I can use
but I'm having trouble finding one. Don't have Partition Magic at this point so I'd like to just find that utility.
Also, it hasn't made much difference it seems in the past but should I have Plug & Play OS enabled or disabled in
BIOS? This is an Epox 8K7A and I'll be installing Win2KPro.
