Need help with a Celeron 900 +440BX
Mannycc
i can not get it to work it is a Soyo 6BA+(440BX, no POST). I Also have an Abit VA6 (Via Apollo Pro, no POST) but i can not get that to work period. even with the old P3 450. The VA6 used to work before i upgraded in july. The Soyo works fine with the P3 450. I'm thinking i need to put a AGP card in the VA6 inorder to get it towork so i can tell it look in the PCI bus for a viseocard. I'll check this in the morning. Please help me.
You may need to flash the BIOS to get a Celeron II to work in there. On some older boards, their original BIOS was released before the Coppermine based Celerons were released. If I remember right the fastest CPU the 6BA+ would support was a P3 550E (w/ the original BIOS), so you definately wana check for a BIOS Update!
Good Luck!
