need help with a calc III hw problem
MrDudeMan
15,069
94
i just need to know that i did this correctly...
i drew it in paint to avoid complications explaining it. its not hard, i just dont remember how to do it exactly. the best i could come up with is the resultant vector is 1.05i - 1.16j
any help would be appreciated
the question is simply find the sum of the vectors and the angle of the resultant from the x axis. this is in 2D. only x and y axis.
my answer:
||R|| = 1.56
theta = -47.85 degrees from +x
ArmenK
1,600
5i-8j+7.9cos30j-7.9sin30i=1.05i-1.1584j
||R||=(1.05^2+(-1.1584)^2)^.5=1.56345
theta=-arctan(1.1584/1.05)=-47.8101 degrees
MrDudeMan
15,069
94
awesome
thanks
Aug 10, 2001
10,420
Just resolve the the vectors into their components and then add them up.
Rx= 5.00-7.90cos(60)= 1.05
Ry= 7.90sin(60)-8= -1.1583
R=[(1.05^2)+(-1.1584)^2)]^(1/2)= 1.5635
theta=arctan(1.1584/1.05)=47.810 degreees below the postive x-axis
MrDudeMan
15,069
94
cool. thats what i did, but i wasnt sure if it was right. just learning ya know =)
thx for the help vesp
