Hi guys, I stopped keeping up with all the latest components because I've been busy with school. A family friend has been asking me to build him a desktop to replace his Pentium 3. The $600 limit is just a guide, it can be expanded if needed.
Proposed build so far
http://www.bestdirect.ca/products/?sku=236955&kw=asus p8z68
1. What YOUR PC will be used for. That means what types of tasks you'll be performing.
Answer: It will be used for mainly browsing the internet, word processing, and some light video editing of home videos.
2. What YOUR budget is. A price range is acceptable as long as it's not more than a 20% spread
Answer: Under $600 would be perfect but lets say $600-$700?
3. What country YOU will be buying YOUR parts from.
Answer: Canada
4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc.
Answer: A reputable brand for Mobo (gigabyte or asus preferably). No brand preference for CPU. I myself own a Intel i7-920 build and an AMD 945 build.
5. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
Answer: Don't need any peripherals. Surprisingly he has been upgrading those as his monitor/keyboard/mice/etc are all pretty new. Also owns a license for Windows 7. I will give him a 500gb hdd for storage. I highly doubt he will ever use that much because his current desktop is 60gb.
6. IF YOU have searched and/or read similar threads.
Answer: Yes
7. IF YOU plan on overclocking or run the system at default speeds.
Answer: Default... No need to overclock yet. His son is only about 4 so maybe in like 2 years if he wants to turn into a gaming PC.
8. What resolution YOU plan on gaming with.
Answer: For now no gaming. But would like the option to drop in a GPU in 2 years if needed.
9. WHEN do you plan to build it?
Answer: Anytime starting now. Can wait if there is something worth waiting for.
I would love to build it around a i5-2500k just so he has some flexibility in the future as more and more apps fully start utilizing quad cores. Bascically, I want him to have this PC for 5 years at least without it being a drawback to anything his son wants to run. A SSD is probably the right thing to do as well. I can give him a 500gb hdd as storage that I have laying around so a decent size SSD would be fine if it can be fitted in the budget. A 128gb preferably to allow for a Windows 7 install and some maneuvering.
Thanks for any advice you guys can give to get me started. The Mobo is what I really need help with. I haven't kept track of the chipsets so really would appreciate it if you can tell me what fits this situation best. Something with on-board video would do fine for now as there is going to be very little gaming. A HDMI port out would be nice but not necessary as he isn't really going to hook it up to a TV I think but having the option to do so would be nice. If any gaming is done, I will get him to buy a GPU.
ASUS P8Z68-V LX $126 -- It has VGA, DVI, and HDMI. All sata/usb requirements would be met also.
Intel Core i3-2100 or i3-2120 124.99 or 129.99 ----> Any difference other than the default clock rate? Might as well get the cheaper one and tweak the bios a little 🙂
G.SKILL F3-10666CL9D-8GBSR Sniper SE 8GB 2X4GB DDR3-1333 CL9-9-9-24 1.5V Memory Kit --- $44
Cooler Master HAF 912 $56 --- I am going to build it and he is probably going to ask me to clean/maintain it all the time. I have pretty big hands and hate working in tight cases so this would do fine as I have one of my own builds in the same case.
Antec Basiq VP 450W PSU $36 ---> I understand the importance of PSUs so definitely wouldn't mind spending more here for a cleaner power supply in the same wattage range. I want to avoid MIR though. Preferred brands here include Corsair, Seasonic, and Antec.
Crucial M4 128gb SSD - $160
ODD --- $20.
Total = $552 before taxes.
Anything I miss? Any conflicting parts?
Thanks a lot guys.
Answer: Canada
Answer: Yes
