iluvnumbers123456789
I bought a couple 3com 3C905CX network cards from newegg, and I can't seem to get them to work. The cards came with a floppy disk containing a preinstall program and a couple other things.
When I run the preinstall program, a message box immediatly pops out saying "Please turn off your computer, install the NIC, and restart your computer." I don't know if something more is supposed to happen, so I'm mentioning it here. The other couple of programs on the disk I can't even get to run at all.
After installing the NIC, I plug in my Telocity (DirecTV) dsl modem and install the software. The installation goes fine the first few seconds, but when the software tries to detect the modem, it doesn't work. I cannot seem to get the connection working using ethernet (I'm using usb now), and I think it may be something to do with my network card. I really need to get the modem working on ethernet so I can hook it up to a router, because with USB I have two computers without internet connections.
Some info that might help:
They are 3com 3C905CX cards from Newegg
I have set this up on Windows ME on some kind of Dell with no success
I have set this up on Windows XP on an Abit KG7 motherboard with no success
I am using Telocity (DirecTV) DSL with a Telocity modem model 10-X203
If you people need any more information, just ask and I'll try my best to figure it out, although I am new to computers, as you can probably already tell.
