Need help with a 3 monitor setup
BostonMike
54
I have a laptop and I need to connect 3 additional monitors to it. I was wondering if anyone out there had advice on what kind of device I need to connect to the laptop. Maybe where to buy or other choices I haven't thought of. None of the monitors are the same size and I will not be using them for games.
IndyColtsFan
33,655
687
Ask, and you shall receive:
Matrox TripleHead2Go
BostonMike
54
Sweet. Thanks blanghorst! That's what I was looking for. I did not realize they would be so expensive though. I'm going to look around to see if I can find a used one to save some $$$.
IndyColtsFan
33,655
687
Yeah, they are pretty pricey. Just be careful if you get a used one to ensure that it has the features you need (works with DVI if that's what you need, etc), because there are a few different versions you can get. We have a group at work that uses one of the versions of the TripleHead2Go, and it is pretty sweet.
