Need help with 2 line unix script
envy me
1,000
I need something very simple yet I cannot get the syntax correct:
assuming :
date // will return a value of Mon Oct 6 22:58:56 EDT 2008
and
date | awk '{print $2,$3}' // will return a value of Oct 6
I would like to do a grep of that value surrounded by single quotes. i.e. 'Oct 6'
and use it in the following way:
ls -ltrR /TEST_Logs/ | grep < date | awk '{print $2,$3}'
essentially I want to list the TEST_Logs directory and all subdirectories and filter it on the date, but it has to be in single quotes because it is 2 words. So my 2 problems are:
1. How do I redirect the date/awk command into a grep?
and
2. What must I change in my awk command to include single quotes?
i.e.
ls -ltrR /TEST_Logs | grep 'Oct 6'
any help is much appreciated.
dinkumthinkum
203
What you want is backquotes, to include the output of a command on the command-line.
But, have you considered using a more apt tool instead, like "find"?
find /TEST_Logs/ -newermt `date`
see man 'find' for the -newerXY option, or other.
envy me
1,000
the -newerxy option is not available for the find command for the shell we are using.
so I can do something similar to
ls -ltrR /TEST_Logs/ | grep < `date | awk '{print $2,$3}'`
but that will do:
ls -ltrR /TEST_Logs/ | grep Oct 6
I need it to do:
ls -ltrR /TEST_Logs/ | grep 'Oct 6'
So all I need is to be able to include the single quotes in my awk command but I've tried enclosing them in double quotes: awk '{print "'",$2,$3,"'"}' but that did not work.
envy me
1,000
this is the best I could figure out. It's not neat but it works:
echo "'"`date | awk '{print $2,$3}'``echo "'"`
envy me
1,000
Now I have combined them both but they do not work.... This is really confusing and irritating. Here's what I got:
ls -ltrR /TEST_Logs/ | grep `echo "'"``date | awk'{print $2,$3}'``echo "'"`
dinkumthinkum
203
What's wrong with "`date | awk '{print $2, $3}'`" ?
You can put single quotes inside of double quotes.
