- Dec 1, 2003
- 880
- 1
- 81
I'm trying to help my friend fix his car. In short, this is what happened: He was driving while it was raining and water leaked into the trunk where the battery is. While this was happening all the lights came on (check engine,...etc) and now the car won't start. This is what I tested so far:
1. No fuses are burned out and the relay switch that kicks in when you attempt to start the car works fine.
2. When I first removed the battery, I used a multimeter to test for continuity between the POSITIVE terminal (from the car, not battery) and the auto body (ground) and there was continuity.
3. We tried starting the car with a booster battery pack, using jumpers from another car, and tried another car battery.
4. I tested for continuity again and there was no continuity between the POSITIVE terminal and the auto body. However, the multimeter displays a number that keeps going up (or down, don't remember). I think this means there is a capacitor within the circuit.
5. When attempting to start the car, the belt on the engine rotates just a bit and then stops but the car keeps making the same noise as if it is about to start.
This is my theory of what happened: Water shorts the battery's POSITIVE terminal with the ground. This is not enough of a short to fry any fuses but enough to damage some sort of capacitor that holds charge to power the starter.
I looked up the started for this particular model and it is a 1.7 KW starter which means it draws about 140 amps! I can't imagine such a motor running without a start/run capacitor. What I think is happening is that the run capacitor (if there is one; I would think that all powerful electrical motors have one) is not holding enough charge to give the starter the torque needed to start the engine.
Does anyone have any experience with this type of problem or have any ideas about what might be wrong? Does anyone know if the starter has a run capacitor and where it would be located (and how to test it)? Thanks for any help!
Once again this is a Mercedes-Benz 1993 400SEL.
