need help wit a radeon 9600 non pro
DimZiE
1,093
need help with my system. i,ve recently replace the display card for my UT2K3 game server from a radeon 9000 pro to a radeon 9600 non pro. i started from scratch reinstalling everything everything seemed dine at first. but after i installed the VGA drivers windows suddenly crashed after BIOS and the windows XP splash screen. i've tried disabling/enabling fast writes switch to AGP 4x and everything i could fiddle . does anyone had the same problem . i assumed there's nothing wrong w/ the other parts since the only thing i replace was the VGA. and i've tried using the 9K pro and the system worked flawlessly. can anybody help me ??
btw the sysconfig are:
Athlon XP 2000+
Kingston 512MB PC3200
ECS KT600-A
InnoVision Radeon 9600 128MB
Seagate 80GB HDD
Windows XP SP1
DirectX 9.0b
Please Help :D
StormRider
8,324
I've had problems with mine too. After installing the Catalyst drivers, it gets to the Windows splash screen and then my monitor goes to sleep. I wait. Then my system reboots and the cycle repeats.
Are you using a DVI LCD monitor? Once I connected the VGA output to something, then I was able to boot up into windows (I have both the DVI and VGA ports connected to my LCD). This happens with an nForce2 based board I just built last night.
With my KT-400 board, it did the same thing but it was unstable (kept freezing on me). Did a complete reinstall and I wasn't able to boot into windows even when I had both the VGA and DVI ports connected. It drove me crazy so I decided to build an nForce2 system to see if there was a problem between Via and ATI.
I'm hoping it will work okay in my nForce2 system I just built.
DimZiE
1,093
thanks man btw i was able to solve the problem by inccreasing the voltage to my AGP port
