trevor0323
My friends PC is in his basement and his wireless router is upstairs, using a USB wireless adapter, I was able to connect him to the network with low signal. Anyways he took the computer over to his friends for a while and finally a couple of days ago we hooked it all back up at his house. So when trying to connect to the network The windows zero wireless program says that I am currently not set up to connect to infrastructure networks. So I go back and check and in the advanced settings and It is supposed to connect to any network. So just to be safe I click infrastructure only mode but for when I close and click OK it tells me that some of my wireless settings have not been saved? Anyways I tried uninstalling the drivers and reinstalling without any luck. In the network utility that came with the device it shows that it is constantly scanning through channels 1 to 11. At this time I brought my laptop over to check if I could get a connection from the network and I sure could. I tried plugging in the wireless router into my laptop which informed that the device has failed and could not connect. This lead me to believe that it was defective. So I ordered a new one of a different model that had good reviews. Anyways I install the drivers etc... and same problem with it saying I am not set up to connect to this type of network. Anyways I am at the end of the line . It is definitely a windows problem, am thinking of just reinstalling XP since he has nothing important on his PC anyways.
