Need help, what speeds are good memory card for Canon camera SD450
Jul 12, 2001
10,142
what are the speed I should get for SD memory for a Canon SD450, i keep seeing different speeds, but no where does canon say what they need
Jjoshua2
635
Generally any speed is good, unless you are taking pictures rapidly one after another, or perhaps a video. If you don't care how many tenths of a second you need to wait between pictures, any memory should work that is the right format. (ie SD for you)
jondl
561
^^What he said. A waste if you don't actually need it.
GrammatonJP
1,245
I use the continous mode a lot... old card was standard sandisk 1gb, 3 pic and saving lag.. new card is kingston 2gb 133x, 0 lags, can take 30-50 pics at a time..
I also have the 2gb adata 50x (i think) from new egg, that works also..
Jul 12, 2001
10,142
thanks i'll try and find a 50x or above
