Ahh.. i dont know whats wrong. I run chkdsk in the command prompt in WinXP on my main drive/partition, the one w/ winXP installed on it, and i get various errors. I run "chkdsk /f" to fix them on the next bootup, which it runs but it doesnt mention any errors/corrections when I watch it scan before windows starts up, it checks clear. Then when i bootup and run chkdsk in a command prompt window in windows again, i get the same errors again.
Any help?
WinXP Pro, 80gig Maxtor D740X HD, single NTFS primary partition w/ 64kb clusters.
Any services/settings I should check?
C:\Documents and Settings\Yossarian>chkdsk
The type of the file system is NTFS.
Volume label is Catch-22.
WARNING! F parameter not specified.
Running CHKDSK in read-only mode.
CHKDSK is verifying files (stage 1 of 3)...
File verification completed.
CHKDSK is verifying indexes (stage 2 of 3)...
Index verification completed.
CHKDSK is recovering lost files.
CHKDSK is verifying security descriptors (stage 3 of 3)...
Security descriptor verification completed.
CHKDSK discovered free space marked as allocated in the
master file table (MFT) bitmap.
Correcting errors in the Volume Bitmap.
Windows found problems with the file system.
Run CHKDSK with the /F (fix) option to correct these.
78172258 KB total disk space.
74859264 KB in 69435 files.
103168 KB in 3494 indexes.
0 KB in bad sectors.
140514 KB in use by the system.
65536 KB occupied by the log file.
3069312 KB available on disk.
65536 bytes in each allocation unit.
1221441 total allocation units on disk.
47958 allocation units available on disk.
Any help?
