dominicanpapi82
I have Windows XP Media Center edition.
1. If you have Windows. Look in your start menu. From the bottom up, on the left, here's what you should see if you have the same operating system:
* Blue Bar that says "Log Off" and "Turn Off Computer
* "All Programs" with a green arrow
* Horizontal line
* Recently used programs
* Horizontal line
* Customizable list of programs which you might use frequently.
My first issue is with that customizable list of programs. I customize it, but when I restart my computer, it resets!! Does anyone know why that's happening?
2. You know when you're writing a text document, and then you go to save it? You know how a list of files and folders comes up, in alphabetical order?
Mine comes up in reverse alphabetical order!! EVERY TIME!!
WHY!?!? That is so annoying when I'm trying to get to a folder and for no reason it's at the end of the files list!!
HELP!! 😱)
* Horizontal line
* Horizontal line
HELP!! 😱)
