Need Help W/Registry!
buzzed365
17
Hi,
I recently installed a game in Win98se. During installation, the pc froze on me before the game was fully installed so I had to reboot. I can't remove the game from my add/remove programs list. Everytime I try to re-install, the uninstallation wizard will come up and prompt me to uninstall the game so I did this but nothing happens. It's still in my system! I can remove the game folder from my program files but that won't remove the game completely. Is there somewhere in the registry where I can remove all the contents of this game from my system?? Any help with be appreciated!
sabresfan
18
Well you can try searching for keywords in the registry, but it's kinda laborous and quite easy to delete something my mistake.
Also try a websearch for regclean. It's a microsoft utility. Be warned...it's far from perfect. Make sure you are comfortable with backing up and restoring the registry before you run regclean
