Need Help w/ Flexinstaller and Proxy settings
neovan
I want to use the Flexinstaller and put SETI on some machines at work but we have a Proxy server and I'm not sure where to put that setting in the Flexinstaller. Or is there a better way to go about installing SETI on some of these machines (some do not have internet access). Is there another program out there that is better suited for me in my situation. Thanks...any help would be helpful.
van
I think the best option is to use a SetiQ on one of your machines with internet access and have your other networked machines get work and pass results through that SetiQ machine. Having a SetiQ makes it very easy to monitor your clients. 🙂 Also, you can point your SetiQ at your proxy/gateway and then when you use the FlexInstaller you'd put in the IP of your SetiQ machine. Makes things simple that way.
Originally posted by: RoborHaving a SetiQ makes it very easy to monitor your clients. 🙂
Yep, so true it should be in the bible 😀
EG: you can leave machines monitor/vid-card/mouse/whatever - less as you dont need to monitor the physical machine. I'd definately go with a queue - the advantage at work is that you wont have to disturb a colleague (assuming it would be installed on other's machines) to find out if SETI is still running.
