Need help w/ "Additional Properties" for tnt2
mricks86
335
I am trying to tweak my tnt2 (Leadtek S320 II AGP w/ 32mb ram) and I have made the "Coolbits" modification to the registry so I can adjust the clock frequencies of the card, but under "Additional Properties" in my video card settings I don't have the tabs for all the other adjustments, like d3d settings, openGL settings, hardware options, etc.
Does anyone know how to enable these? Any help would be greatly appreciated. I am running win2k.
Thanks in advance!:)
mricks86
335
Last time I checked this was the "video" forum, I didn't see one specifically for "video cards".
merlocka
2,832
youd get a better response in the vid card forum
Someone is lost ;)
Which driver revision are you using? nVidia reference drivers? Leadtech drivers? A bit more detail and someone can help.
BFG10K
22,709
2,999
That usually happens when you install new drivers without uninstalling the old ones first. If you did this, uninstall the current drivers and then reinstall them.
mricks86
335
Thanks for the input, I appreciate the help. I may have done exactly that, installed the new drivers before removing the old ones, so I'll give that a try. :)
