Need help /w a math problem
blahblah99
2,689
Originally posted by: Chu
Can anyone tell me what the equality symbol in this problem means?
link
Probably means less than or equal to whenever you see that symbol, or greater than or equal to. I think it's just a lazy way of writing concatenating two problems into one.
dullard
26,078
4,729
To me it appears like 3 problems. Prove it when using a '>' sign, then prove it when using an '=' sign, and then prove it when using the '<' sign.
I could be wrong though.
raptor13
It's a cases problem. You have to prove the first statement when k takes any of three values... <, =, or >.
Sucks to be you! ;)
TuxDave
10,571
Yeah, prove it for both 'less than' case, prove it for both 'equal' case and prove it for both 'greater' case
MrSmithers
500
I agree, 3 seperate problems. OTOH, what the hell kind of English is "according as?" I would call total shenanigans on the whole problem based merely on that.
Smithers
CSMOOTH
180
Here is my thoughts on it... Take it as you will:
The rest is trivial...
So if you expand the nCr on both sides you get:
n! / [ (k-1)! * (n-(k-1))! ] ? n!/[k! * (n-k)!]
the numberators are the same so if the denominator is the greater on the left then the value to the right is larger (sign inversion). eg. 1/6 < 1/5
so you have
(k-1)! * (n-(k-1))! ? k! * (n-k)!
substitute
K! = (K-1)! * K on the right side and you have
(k-1)! * (n-(k-1))! ? (K-1)! * K * (n-k)!
Divide through by (k-1)!
(n-(k-1))! ? k * (n-k)!
substitute n-(k-1) = n-k+1
(n-k+1)! ? k * (n-k)!
substitute (n-k+1)! = (n-k)! * (n-k+1)
(n-k)! * (n-k+1) ? k * (n-k)!
divide by (n-k)!
n-k+1 ? k
add k to both sides
n+1 ? 2k
rewritten:
k ? (n+1) / 2
-Smooth
