Need help!! video card is wacky!! please read!! ^_^
kitkit201
4,853
hey everyone
i need your help!! i have a visiontek geforce2 gts 64mb ddr card and i booted my computer and the screen is all grey!! i swapped cards to my ati card and my computer runs fine.. something is wrong with the card.. i dunno what.. is it short circuited or something? i been having really bad luck with computers as of late.. first my cdr drive XP and now this.. any advice? thanks
wilson
spanky
25,716
4
uninstall and reinstall the driver? reseat the card in the agp slot? make sure cables are snug? after that... ur card might be dying. try sticking it in another machine and see how it performs.
bikinistud
50
just wonderin' if you have power strip/or any overclock tool to overclock ur card. if so boot up with the ati and uninstall the overclock program. then try and boot up.
otherwise do what spankyOO7 suggested.
Good Luck!
