Need Help using submit button onclick in PHP
faisal83
How to pass the value using onclick button??
<?php $book_id = $_SESSION['book_id'];
$query = "SELECT * FROM books WHERE book_id = '$book_id'" ;
$result = mysql_query($query);
$numrows = mysql_num_rows($result);
if($numrows==0){
echo "<script>alert('No record for $book_id');</script>";
if($numrows!=0){
<form action="returnsearch.php" method="post" name="form">
<table border="1" width="96%">
<tr bgcolor="#E9AB17">
<td width="12%"><div align="center">NO. RECORD ID</div></td>
<td width="13%"><div align="center" >NO. BOOK ID</div></td>
<td width="53%"><div align="center" >TITLE</div></td>
<td width="22%"><div align="center" >ACTION</div></td>
</tr>
<?php while($row = mysql_fetch_array($result)){ ;?>
<tr>
<td height="26"><div align="center" ><?php echo $row['no_id']; ?></div></td>
<td height="26"><div align="center" ><?php echo $row['book_id']; ?></div></td>
<td height="26"><div align="center" ><?php echo $row['title']; ?></div></td>
<td height="26"><div align="center"><input type="button" name="submit" value="Hantar" onClick="????">
</div></td></tr>
theknight571
2,896
Can you explain a little more what you are trying to do?
Is this the code from "returnsearch.php"?
In the past, when displaying rows of data that I wanted to show details on, I've used links that were built on the fly instead of buttons. I have used images so it looked like a button, but it really was just a link or I've made the ID number into a link that calls the details page...
href="returnsearch.php?id=1"
href="returnsearch.php?id=2"
Then in the returnsearch.php page I use the $_GET['id'] to get the number they selected.
I don't know if that's what you are trying to accomplish or not or if there are other reasons you are trying to use the on-click.
