"Eug, please elaborate on what you meant by: "or possibly PIII 700E, depending on your memory and video"
If you have memory that can handle a 133 MHz bus and a video card that can handle 89 MHz, then you may be able to hit 933 with a cB0 700E. Most vid cards can handle 83 and some PC-100 CAS 2 memory can handle 124 MHz at CAS 3, so that would be an option too, since a PIII 868 is pretty damn fast. Also, the PCI bus wouldn't be a problem because there is an option to run it at 31 MHz instead of 41.3 with the FSB at 124. By the way, a 700E at stock speed is probably about the same speed as a Celeron 850, so even if all you can get is 784 MHz out of a 700E that's still pretty damn good.
"The limit of 1.80 volts is fixed by the board.....it's not able to supply a lower voltage."
"Some of the later rev 1.10 boards have voltage regulators that allow voltage of 1.6v."
My 1.10 goes down to 1.5 V for sure, because the only times I've ever run this Celeron 533A at stock speed was at 1.5 and 1.6 V.
"Have one running a Celeron 566 at 850 at 1.65v with an MSI slotket."
If you're still talking rev. 1.10 that is bizarro. My 1.10 usually will boot at 1.7 V if I set it to 1.65, but a couple of times it just refused to boot. (Same thing at 1.75 --> 1.8.)
