I am looking to upgrade my processor on my computer and have never done it before. I built my first machine from scratch just shy of 2 years ago and I haven't tampered with it since.
I've got the following running currently:
AMD Athlon 64 3200+ (Venice) Skt 939 processor
ASUS A8V Deluxe (via K8T800Pro chipset) for Athlon 64(FX) Skt 939
I want to upgrade the processor only and I want to be sure before I buy it that I can easily swap it out. I wanted to find out 2 things.
1. Can I get any newer AMD Athlon 64 or FX processor as long as it is Skt 939 ? Because they also now list X2 Dual core processors and FX processors are really expensive. I'm mostly looking at the 3800+ or 4000+ or the X2 dual core processors if they would work wiht my motherboard.
2. Do I need to do anything besides pull the old processor out and insert the new one w/heatsink?
Thanks in advance, Rob
