need help upgrade 600$ budget
dasein007
i got this motherboard p5g41-m lx2 series which is only INTEL
http://www.microcenter.com/single_pr...uct_id=0330333
mainly looking to upgrade to play StarCraft 2 and Battlefield bad company 2
looking to upgrade CPU, graphics card, memory, and i prefer some brands like corsair, intel is by force since motherobard, ATI
here is my list
http://www.newegg.com/Product/Produc...82E16820145195
for graphics
http://www.newegg.com/Product/Produc...82E16814102858
for CPU
http://www.newegg.com/Product/Produc...82E16819115037
for hardrive
http://www.newegg.com/Product/Produc...82E16822136284
and im upgrading to windows 7
http://www.newegg.com/Product/Produc...82E16832116754
tell me what u guys think and i think im already over the 600 budget, THANKS for your time
Please don't tell me by "got" you mean already bought. There are much better AMD options in that price range.
E8400 is a blazing dual-core, but that limits it at a dual-core...BFBC2 gets a boost in minimums with a quad-core. Even with a mobo, you can get a 955BE + mobo combo deal at Fry's for less than that.
ok you convince me, tell me the AMD CPU i should get and an motherboard, please, thanks for ur time, i appreciated, i would like to keep the CPU under 200 if possible, thanks.
