clickynext
Cliffs at bottom.
I'm in a strange sort of problem brought on by my own short-sightedness (figuratively that is).
I was installing shifter bushings for my car, and when trying to remove the bolt on the outside of the bushing stud, the entire stud came out, unscrewing from the side of the gearbox because the bolt on the outside was really rusted on there.
So I took the bushings and washers off, and figured I should screw the stud back onto the gearbox before I put the bushing and shifter link on it. I used a wrench to put it on tight by turning the bolt, but then suddenly when I got to the end the bolt came loose because I guess the rust finally gave, and that's when I realized that I forgot to put the washer back on the inside.
And now that there's no rusted bolt to use to turn the stud, I don't know how I can get it back out to put the washer on. Attached picture shows some of what I'm talking about. I basically need to figure out a way to turn the thing in the first picture counterclockwise, and without ruining the thread on the outside.
Any help would be greatly appreciated, my car is jacked up right now...
Thank you!
Cliffs notes: How do you unscrew that entire stud in the picture? The black part and the threaded part are all one object.
http://members.shaw.ca/clicknext/bushing stud.jpg
Thank you!
