KhoiFather
I was trying to unscrew this nut bolt that helps keep the front bumper on and it the top of the nut bolt decided to break and leave the screw stuck in the hole. So I figured I can try to drill a needle in there and try to drill it out but no luck. Any suggestions and what I can buy to help me get it out? Need help quick!
