Need help unlocking? or setting up an old TV
orion23
Hi!
I was given 2 old TV's. Panasonic, 19" and whenever I press any of the front buttons, the main menu comes up, but I cannot choose any options.
All buttons do the same, volume, channel, video, and menu. Not even the remote control works.
Both TV's do the same thing. Could it be that they are just locked? Like the TV's they use @ doctor's offices, so that people don't go changing the channels?
Thanks!
Thanks for your reply...
I tried the first method and it didn't work.
The Remote Control doesn't work so I cannot try the second one.
If i hold the Power button + any other button @ the same time, the TV does a "self test" but not a reset function..
Up again!
