Need help understanding
ktorrresxiii
23
If a case radiator support says top 2x 120 does that mean a 240mm radiator is good to go up there?
Sorry if it's a dumb question
Tweakin
2,532
Then the answer is yes:
Hope this helps...
BonzaiDuck
16,889
2,208
Uhm yes, a 2x120mm is commonly referred to as a 240mm rad.
Tell ya what I'd like to see, after looking at my HAF cases and this radiator:
http://www.frozencpu.com/products/1...200mm_Radiator_-_Version_2_-_Full_Copper.html
a "400mm" radiator . . . .
And if there's no case that accommodates it, I can see -- looking again at the HAFs -- there's a way to mod the case, make it wider, and keep such a monstrous radiator and the two fans from inconveniencing periodic access to the usual left side-panel.
I guess I'd give myself a trip to the local metal-supply across town, and a week or two to build it . . .
