Need help understanding what ATV tires sizes mean.
AaronB
1,214
Alright, I can figure out for myself that the 21 and 22 parts are the tire heights. As for the other two numbers I'm guessing they are width and rim sizes but I'm not sure which is which. Educate me. :)
BTW, I need to get some tires in the sizes mentioned above (21x8-9 & 22x10-10). Are there any good places online to find them?
Evadman
Administrator Emeritus<br>Elite Member
Feb 18, 2001
30,990
Diameter X Width - Rim.
21x8-9 = 21" tall, 8" wide on a 9" rim.
AaronB
1,214
Any suggestions on where to buy tires? I can find plenty of of places via Google but personal recommendations are a plus.
Visiting the local atv shop is like getting gang raped by a pack of gorillas.
JDMnAR1
11,984
If you aren't looking for a specialty tire, check your local Wal-Mart. They usually cary plain jane ATV tires.
