BeakerChem
Hi all,
I am trying to figure out what I need to get to protect my system from the power problems I am having in my new place. We get light dimmings periodically and it doesn't seem to be due to anything in the house (not timed to the AC or fridge).
I just want to regulate the voltage to the computer, but here is where the problem comes in. I am running an X2 4800+ with a BFG 7800GTX etc... and using a 600W PSU. The friendly staff at Bestbuy sold me a UPS that is only rated up to 330W, saying that it is enough if I only want to use the voltage regulation portion (although searching online says that the systems work by pulling entirely from the battery and charging the battery from the wall, which means that 330W won't be enough at all.)
So, do I need a 600W UPS system, or is there a system out there that just runs AVR. I found a couple, but I don't know the quality and there don't seem to be any reviews on these sorts of things.
Candidates for AVR only:
OptiUPS brand AVR (Only AVR - no battery)
APC's Line-R unit
Anythoughts on if these would be big enough units to work with my system and/or if they are ok companies?
Thanks!
APC's Line-R unit
Thanks!
