Need help understanding LCDs for gaming...
Findedeux
I am looking into buying an LCD for gaming. The thing is I've heard a lot about ghosting issues, as well as viewing angle problems, etc. However, for the last 3 years I've been using the LCD from my Presario R3000 laptop, and haven't noticed any such issues. I looked up the specs and they're pretty pathetic with a response time of 25ms. So my question is how can these be problems when I don't even experience them on my old laptop LCD? BTW, the LCD I am looking into buying is the Samsung 204b.
Denithor
6,298
23
I use the Samsung 204B for gaming (mainly FPS and recently a lot of WoW) and have absolutely no ghosting or any other problems for that matter. Love this monitor. Only issue is that text is kinda small (but super sharp) at 1600x1200 on a 20.1" monitor.
jcenters
59
Most of the complaints you'll hear about modern displays are about TN panels. They're typically found in 22" displays.
Personally, I have a 22" Samsung 220WM and think it's great. This is coming from a guy who used to be fanatical about his Viewsonic A90f.
Worst thing about LCDs, imo, is that you either run them at max resolution or they look like crap.
0roo0roo
64,795
84
under 12ms or 8ms is fine
its no longer a huge issue.
now its just the difference between passable and awesome.
betasub
2,677
Older LCD panels presented some of the problems you mention for some ppl. Modern LCD panels have improved in all these areas and are accepted to almost all users.
Concerns about these problems won't die out because the internet keeps them alive, however out-of-date they are. Just like the repetition across the internet that "brand X has incompatibility issues" (whatever that means).
Nomadic
Samsung Has launched 5ms LCD monitors They are the best you can go closer to a CRT in gaming . Low response time means High FPS :D
Markbnj
Elite Member <br>Moderator Emeritus
Moderator
Sep 16, 2005
15,682
14
www.markbetz.net
Doesn't the monitor still refresh at 60hz? Or are some of them 75hz at higher resolutions now? I thought the primary advantage of the faster response times was crisper transitions between color states, not more frames per second.
