hybrid2d4x4
Hello all. A computer I built for a friend is acting up intermittently (but often enough to be bothersome). The obvious symptoms are background app/process crashes usually right after boot, and BSODs (esp while shutting down - the "Windows is Shutting Down" screen). Basically it's a lottery whenever you power it on. Sometimes everything works perfect, other times you get odd app behavior and crashes and you have to try again. Before I go on, here are the specs:
Gigabyte P55M-UD2 (F8 BIOS- latest as of a week ago)
i5 750 @ stock speeds, auto voltage; cooling via CoolerMaster 212+
2x2 G.Skill Ripjaws rated for 1333MHz 8-8-8-21@1.5V but running 9-9-9-24@1.5V
ATI 4770
WD 160GB SATA (old)
LG IDE CD burner (old)
Antec 300 case /w Antec EarthWatts 380W PSU
Temps are really good: idle- high 20s for CPU, ~45 GPU; load- high 40s CPU, low-mid 50s GPU /w vRAM+VRMs in the 60s. Ambient= 18-20degC
Currently running Win7 HP x64, but the issues occurred on the previously installed WinXP OS, so I'm leaning towards hardware issues.
I spent most of one entire day doing HDD diags including full surface tests, mostly using WD's Data Lifeguard utilities, and there was not a single error.
I ran the Windows Memory Diagnostic (extended test, 10 loops) and it was going fine for ~8hrs until I plugged my ipod into the USB to charge and it did a hard reboot. Reseated RAM,etc at this point.
I've been running Memtest86+ v 4.00 for the past few days, but it's been inconsistent. Initially running both sticks threw me errors within 3 hours. Running one stick at a time was error-free for 3.5-4hrs for both sticks. Running both threw errors, especially when trying to run 2 stick in single-channel mode (in fact it didn't even detect the 2nd stick when running them in the 2 adjacent middle slots slots, #'d 1&4). Tried reseating CPU and ran P95 torture test to make sure heatsink seating is ok (for temps). Temps were great, but one thread failed in ~1hr.
Went back to running Memtest, and it went for a lil over 8hrs on both sticks without errors before I called it a night. The next day I let it go at it again and it survived over 20hrs in Memtest without any errors.
This inconsistent behavior in benchmarks/diags is pissing me off. Other than testing with known-good RAM (which I'll hopefully be able to do if a friend "trades" me their RAM for a few days), I'm starting to run out of ideas. It looks to me like it could be the RAM, mobo or CPU, but can't really tell which. Anyone have any further ideas or any CPU-specific benchmarks/diags to run (preferably outside an OS environment)? Any help would be appreciated...
ATI 4770
WD 160GB SATA (old)
