Need help to view DVD on LCD monitor
billnrhodes
Hi Everyone, Just joined here in hopes of getting some help with this. I have an HDTV set top box with a built in DVD player LG LST3510A. This box puts out an excellant picture to my hdtv with DVI input. I wanted to try it with my LCD monitor thats on my computer. I use the RGB connection to my monitor and can watch HDTV ok. I try to watch a DVD and get a copywrite message that tells me I cannot view the DVD useing the RGB. Well the monitor only has the 9 pin RGB input. The box has all these outputs..coax, composite, component,9 pin rgb, and dvi hdtv. I want to use any but the coax or composite. The reason is becuase with any of the other outputs the signal is digital or upscaled. Where can I get what I need or instructions on assembling what I need. Thanks for your anticipated help. Bill:confused:
Matthias99
8,808
You need a display that supports DVI with HDCP, generally, to view copy-protected output from an upsampling STB or DVD player on a digital connection. RGB and component are not copy-protected, so you cannot output digital copies of copy-protected programs on those connections. If you do not have an HDCP-compatiable DVI input on your LCD, you would have to use coax/composite/S-Video (which are analog connections). You can thank the MPAA and the DMCA for all this crap (not that it's stemmed piracy in the least...)
billnrhodes
I goofed up. My LCD monitoer has a 15 pin input as does the HD box. Does anyone know if it will work going from the DVI and converting the connector to the 15 pin RGB?
Matthias99
8,808
You can't convert DVI-D to VGA. "DVI to VGA" adapters are for DVI-I connections, which carry an analog VGA copy of the signal parallel to the digital DVI one. You really can't watch copy-protected HD feeds over VGA -- no HDCP-compliant hardware will let you. It *might* work if you output at 480i or 480p.
