Need Help to test MOBO
shreeit
68
My new system is not working. No power to fan. I tested PSU. PSU is fine. Now it's time to test MOBO. I connected PSU 24pin connector and 4 pin PIN to MOBO, CPU fan connector to MOBO, RAM and speakers.
Anything else I need to connect to see if it's working or not? DO I have to connect power switch pins from case to MOBO? I just wants to see if PSU fan and CPU fan power up or not.
THis is 945PSN intel MOBO with Pentium D CPU.
Thanks,
joincamp
120
without jumping the power switch pins, I see no other way of turning it on, so yeah I would go ahead and connect it up.
shreeit
68
Is there any way I can closed the loop without connecting power switch pin?
Thanks,
shreeit
Atheus
7,313
Short the pins with a screwdriver, just don't scratch the PCB.
