Need help to pick up a case
Wolverine88
ok, first I haven't assemblied a PC for a while. The recent one I did was about one year ago.
Now I am trying to pull up an P4 or AMD XP box. I heard that there are some special requirements for case. Is Antec 830/1030 any good for such system? Or what are those requirements indeed?
Any Motherboard recommended? esp Dual CPU board. thanks.
I use the Antec SX830 cases, And love them.🙂 I pull the stock PS out and install Entermax 430W PS's. The Cases themselve are great just make sure the PS in it is what you want, I think they come with several different Wattages. They use AMD and P4 Approved PS.
The enlight cases are pretty good too...I have one with an Enermax Power Supply and it's been pretty rock solid so far with my K7S5A....
I think I may go for another PSU with more power though since I want to add more devices...
The Evercase 4252 is worth a look since it is inexpensive, tool-free, and has front USB. Check out Hot Deals because you can get it for $40.
