Hi,
I bought a new black ice 2 radiator and while testing my new watercooling setup for leak, I found out 1 of the fittings of the rad was leaking. I tightened it to very tight already, but it did not fix the leak. The fitting already has sealant tape on it, should I buy and apply another layer of tape? What else can I do to fix this?
Thanks in advance for your help.
