need help to filter records in SQL
leeland
Hello
I have a huge SQL view I am writing at work and I have come across a problem as far as filtering records. I have a record set that gets returned but there are duplicate records.
for instance
Rec URN Name sequence #
123123 bob 1
123123 bob 2
Now everything in the records is identical except for one field, so it is getting counted twice when it should only get counted once.
In the SELECT part I have some aggerate functions so I have to use the GROUP BY command for the rest of fields that are not aggerate.
There has to be a way to only select one record based on the URN vs both of them
I have tried the disctinct command and that didn't work within the SELECT statement.
Any ideas would be helpful
Thanks
Leeland
Take out the sequence# field out of your query/view and all should be well in the land of SQL.
well that is the problem I know it woudl be that easy to just take that out but I can't unfortunately 🙂
I did get it to work but I think I did it a jimmy rigged way
I had to put Max( fieldname) around every field in the select statement
Then in the GROUP BY
the only field I used was the Rec_urn
That grouped the duplicate fields together and only counted one record. I don't think that is the right way to do this but it works
CREATE OR REPLACE TABLE 2ndtablename
AS
[...your select...]
SELECT DISTINCT * FROM 2ndtablename
ROFL very gross indeed
I'm no database person so there is probably a much cleaner way of doing it (this way is slow because two selects take place)
Can you do a select distinct URN on the SQL statement you have now?
Ex. x = your current SQL statement.
select distinct URN from (x)
I tried that and for some reason it didn't work
here is what I had
select
distinct(rec_urn)
xxx
xxx
xx
FROM
table
WHERE
criteria
and it still gave me the duplicates
The only way I got it work was this way
SELECT
rec_urn
Max(xxx)
Max(xxx)
FROM
table
WHERE
criteria
GROUP BY
rec_urn
that way it grouped on the REC_URN and did not give me the duplicates...I still don't fully understand why the DISTINCT function didn't work
I think it might be because the it looks at the record (or row) as a whole vs just the column of REC_URN
is this a wrong way to look at it ?
so if the records were like what I posted above
123 microsoft version 1
123 microsoft version 2
it would see that each record is actually disctinct within the list and still include them....
I have to ask some people at work about it still to see if they can give me a decent answer
thanks for the info guys
Leeland
