need help to configure SLI
Oldjazz
Hi!
My name is Andre and I've bought 2 Leadtek 7900-GTX and when I run 3Dmark03 or 3DMark06 (didn't try other Benchmark yet)
I'm getting some problems, at the end of the test I'm getting a blinking screen and I can't see the results but tried those two with one of my two 7900 GTX and I got no problem, I only get that in SLI mode.
Configuration:
Asus A8N32-SLI Deluxe "1303 Bios"
AMD Athlon 4200+ X2
Corsair 3500LLPro 2048meg (2 x 1024) in Dual Channel set up at 2.3.2.6 - 1T
2 x Leadtek 7900 GTX 512meg (each) linked with bridge wire
running them on Nvidia latest drivers (91.47)
Ultra 600w SLI ready power supply
Viewsonic VX922 monitor
Windows XP Pro
3 Sata hard drive
No overclocking done.
So I'm a little bit disapointed that I can't run a test to see the difference between one card and two cards.
But it looks like they work fine in games though but I can't verify that.
In the first Ghost recon I was getting only 60fps until I've install the Refresh_Rate_Fix_Nvidia then I was getting 500fps.
Not a lot since I was getting over 700fps with an FX5900 128meg using the drivers from :
http://www.omegadrivers.net/nvidia/win2k_xp.php
In Ghost Recon Advance Warfighter I get between 45fps and 65fps so I don't think it's the best that I can do with those cards.
Do someone know what to do or got similar problems and went thru them?
Best Regards.
André.
You might want to alternate your gfx cards, and the slots their in, make sure both slots work fine and that both cards work fine. Sorry mate, not much i can do with this one, havent tried SLI yet 🙁
