Need help to configure azureus
Ive tried the tut at portforward.com, but i already have a static ip with my isp, so i dont know what it is. Some one please help me forward some ports.
Do you know how to log in to your router and find the port forwarding page?
And 40 minutes is way too early for a bump 😉
Go to the Options menu in Azureus (I think it's under Tools) and see what port Azureus is using. Then log into your router and go to the Port Forwarding section. Type in your IP address and the port number you found in Azureus. Make sure the port is forwarded for TPC and UDP traffic. Save settings, that should be it. Then I think you can check in Azureus somewhere if ports are correctly forwarded.
Originally posted by: thecidsound
What do I type for server ip in the portforward settings for azureus?
In your router settings page? The IP address of your machine. If you don't know it, open up the Command Prompt (I'm assuming you're using Windows) and type "ipconfig". It will give you your IP address.
Yes, but I don't think most home routers will actually change the ports in NAT forwarding. If you have to put two numbers in, it's probably a range.
